Sound system for TV (Movies and TV shows)
25 Mar 2004
Fareham
Hi,
I have a soundbar connected to my TV at the moment (model is Samsung HW-F551, this is the silver one, the F550 is the black version).
I am not that impressed with the sound quality overall and would like to look at investing in some better sound hardware. The sound is quite bassy so I would like something with more presence.
This is primarily for watching tv shows and movies. The room is around 10ft x 10ft.
I'm not sure on what is best, 2.1, 3.1, or 5.1 on a separate amp, or a better sound bar. I don't want to attach any speakers to my walls or anything but can deal with putting them on stands etc as required. I want any system I install to be movable.
I would like something that could last many years, so my budget really would be around £1K tops I think, can anyone recommend a good setup with this budget in mind?
Thanks!
Your options:
Budget sound bars are generally more about convenience and compactness. When you start getting to the Yamaha sound bars at £700+ then the performance is pretty good, but it's still topped by a full 5.1 system or a decent 2.0 Hi-Fi system..
A good stereo system (2.0) will work pretty well for TV and movies. Decent standmount speakers will provide enough bass to be convincing but without the boomy one-noteness of the Samsung. The only issue is your main sources are digital right now (TV and other?), and that trend will increase in the future. Hi-Fi amps don't have digital inputs as a rule. There are additional boxes that can be used as to bridge the world of digital and analogue though, so it's not the end of the world.
2.1/3.0/3.1 systems are really just cut-down versions of 5.1 systems for people who don't need/want the extra speakers. In truth, any 5.1 system can be configured with a smaller number of speakers; so you could easily leave two speakers wrapped up and set-up as a 3.1 system now, then break out the other speakers when you have more space.
Full 5.1 systems give you the greatest flexibility. As mentioned above, the amp can be configured with any speaker combination from 2.0 upwards. A decent AV receiver with just about all the connections you'll need for good future-proofing with a broad range of sources, and it will handle the widest range of signal formats.
Speaker stands are also available for the smaller satellite speakers you'll find with a typical sub/sat 5.1 speaker kit.
If your focus is primarily TV and movies, then a 5.1 system probably makes the most sense.
Some equipment choices to consider:
When you start looking at decent Hi-Fi and AV gear then it's common to mix-n-match products. So, you'll choose speakers from specialist speaker manufacturers and combine them with electronics from Hi-Fi or AV equipment makers. This is the way to get best-in-class performance.
Speakers - 5.1 packages:
Monitor Audio Mass 5.1 @ £599 - incredible performance, excellent with music as well as movies. Capable of seeing you through several amp upgrades and would be perfectly at home being driven by a £1000 AV receiver as a £300 one.
Wharfedale DX1 HCP £300-£350 depending on black or white finish - Great performance with TV/movies, not too shabby with music.
AV Receivers - full height:
Yamaha RXV675 refurb @ £249 - incredible value when you consider this would have been discounted to £399. Great movie performance and decent music performer too.
Yamaha RXV677 @ £389 - later model that 675. Same virtues.
Pioneer VSX924 @ £249 - if you're interested in creature comforts such as Bluetooth / Apple Airplay / Network streamed music then this should be of interest.
AV Receivers - compact/half height:
Marantz NR1504 - all the features of a full height AV receiver but in a smaller package. Some slight compromise on sonic performance for the space saving, but still a great AV receiver for movies.
Your options:
Yeah thought that might be the case.
I have the following:
Rpi2 running Kodi as Media Centre device. Attached to TV via HDMI. This streams TV/Movies over the network via my Syno NAS.
PS4 also attached via HDMI. Just use this for games no Blurays or anything.
My mobile devices can stream audio for Spotify via Bluetooth.
TV connects to Soundbar via HDMI using ARC port.
TV also has an Optical port for sound if required.
I don't use, or plan to use, any kind of tv based devices like Sky boxes, Virgin Media, Tivo or whatever. I just need the above to connect and work :)
It's not really a space issue for me, I just don't want to attach rear speakers to my walls or anything. If I can run them to stands and have pretty long cables it could still work, would need to be able to run speakers for quite a distance to get behind my corner sofa though.
Would a digital amp dedicated for sound be better than an AV receiver for me? I would just really be attaching speakers to it, My Rpi2, and my PS4 I guess. So I wouldn't need to switch audio outbound source, and for video just between the Rpi2 and the PS4 really (which I can do from the TV).
Yeah it probably is, just need to really find the right set I guess.
These prices from RS I guess right?
I attached my NAD hybrid amp and my Dali Zensor 3 speakers to my TV and they work pretty well (this is just a 2.0 system, I could prob make it pretty awesome with a sub for them as well to get 2.1).
5.1 may be best but perhaps a good 2.1 system would be better than a mediocre 5.1 system?
The NAD amp and Dali Zensor 3 speakers are really my PC speakers, but something like this, maybe with floor standers and a good sub instead of the bookshelf speakers would be ideal for me?
At the moment your TV is acting as the switching hub. The direct consequence is that it is very likely that the TV "downscales" any audio to either basic stereo or it passes Dolby Digital but nothing better.
The Samsung sound bar has limited audio performance. So the difference between a stereo and DD isn't going to be night and day. Your D3020/Zensor 3 combo has much better resolution, but the PCM stereo source signal from the TV won't be good enough to take full advantage of it.
If you'd have approached this saying "I'm really in to music. I have a great CD player (or have spent loads on a PC system for stereo playback), can I play movies and TV through my system?" then the answer would have been yes, with the caveat that TV audio isn't the same quality as good 2ch music.
Your starting point though is different. It's TV, movie rips and a bit of Bluetooth audio. A stereo system will do okay with that, but so will a surround system; and the surround system will give you some creature comforts and future-proofing that the stereo system lacks. So the answer depends very much on your starting point.
Surround in a 10ft x 10ft room: It not going to pose much of a problem technically for the equipment. With decent cable you could wire up a 50ft x 50ft room.
mediocre 5.1 system vs good stereo: I'd hardly class the MA Mass & Yamaha AV receiver as mediocre; far from it! Even the Pioneer and Wharfedale gear would surprise you.
If you were talking about pure high-quality stereo source signals then go the stereo route. But what you've said about it being mostly for TV, movies and some BT audio, then I think you'd be just as well (if not better) going for a decent surround system for your gaming and rips.
Floorstanders will need some room around them to breathe. Zensor 3's on stands with a sub makes better sense. The bass element will be more controllable thanks to the adjustments on the sub. You'll get the same controls on the Wharfedale and Monitor Audio subs.
In the end go with what your heart is telling you. If you hanker after some floorstanders and a sub then do it. Zensor 5's are £550. You'll need a pretty decent sub to supplement them properly; a BK XXLS400 (£425) or Monolith (£455) would be appropriate.
I had a quick look at the reviews etc, for the AV receivers I have basically boiled it down to:
Yamaha RX-V677 £389
Onkyo TX-NR636 £449
Sony STR-DN1050 £419
I actually really like the sound of the Sony one, according to the what hifi review it can do BT, and plug into Spotify directly as well which would solve my streaming requirement. Onkyo are normally well regarded but seems to fall flat in the reviews.
The Monitor Audio Mass 5.1, are they the best in breed for this kind of price range do you think?
Yamaha for sound quality.
Onkyo used to be the leader for price/performance, but did/do suffer issues with HDMI sockets failing.
Sony is chasing the middle market with power and features. Some like the sound.
MA MASS and Focal Dome - both Best in Class IMO
I was very pleasantly surprised by Focal Domes. They sound very similar to my old MA back pair of surrounds and are much more SWMBO-friendly.
I've had a look around, and the Focal Domes and Monitor MASS speakers seem to be EOL. The Domes had one set left over at RS but I'm not sure on them personally, at least aesthetically.
If I consider the best AV receiver choice to be the Yamaha RXV677 then I have a few options for bundles that I would like to seriously consider as I save a good deal on the amp/speakers when purchased together.
These are 4 deals I am looking at (don't think I can get the first one anymore though). What would you guys pick here?
Yamaha RXV677 with Monitor Audio MASS 5.1: http://www.richersounds.com/package/system-savers/home-cinema-separates-bundle-deals/pah011827 £799 but OOS.
Yamaha RXV677 with Q-Acoustics Q7000i: http://www.richersounds.com/package/system-savers/home-cinema-separates-bundle-deals/pah011894 £989
Yamaha RXV677 & Dali ZENSOR 1 5.1: http://www.richersounds.com/package/system-savers/home-cinema-separates-bundle-deals/pah011828 £1079
Yamaha RXV677 & Monitor Audio BX2 5.1: http://www.richersounds.com/package/system-savers/home-cinema-separates-bundle-deals/pah012237 £1079
I checked with RS and they can't do a demo on the Monitor ones but I can still buy them from them, just can't see how they sound beforehand.
For the Dali speakers the guy suggested buying a pair of Dali Zensor 3's for the two front speakers instead of the package ones, they would reduce the price accordingly for the package but I would pay a little more for the bigger Zensor 3's.
