Soundbar for small 27" monitor?
17 Oct 2012
Hey all, I have an AOC 27" monitor on my desk which I use for my XB1 and PS4. The built in speakers are pretty bad.
Unfortunately I do not have anymore space on my desk to put some decent speakers to the side, nor does the monitor have a VESA mount, which otherwise would allow me to place the speakers just below.
Does anyone know of a decent horizontal sound bar, not wider than say 60cm, and higher than 10cm? I plan to have it sit just in front of the monitor. I'm hoping to not spend more than £100.
Also, the soundbar is going to be mostly used when I'm on Netflix, YouTube or Twitch. When I'm gaming and on Destiny, I have my headset on anyways.
Thanks!
sound bar + monitor doesn't really work. most are bigger than 120cm never mind smaller than 60cm.
get yourself some decent 2.0 or 2.1 speakers that have optical input (2 would be nice but you could use 1 with an optical switch that you need to switch manually every time you switch console, a bit of a pain but it will work flawlessly).
forget the sound bar idea
