Soundbar recommendations, maybe even a 2.1 system
8 Aug 2013
Stoke-On-Trent
Currently i have a Sony HT-XT1 but ive decided to have a change around and put the TV up on the chimney breast so unfortunately I won't be able to use the Sony base anymore.
So looking for a soundbar to wall mount under neath the TV or possibly a 2.1 system if I could figure out speaker placement as I would have to move a few things to make room either side of the chimney to place speakers.
Budget is around £250-300 ones I have looked at so far are the Yamaha ysp 1400 (2nd hand) and the Phillips HTL5140.
Any other recommendations?
I've bought 2 YSP 1400's second hand for £150 and £160 including delivery.
For the money I don't think you will get any better. The yamaha subs are also really cheap that go are compatible with them @ £50 or £75 brand new. So if you feel bass is lacking you can kick it up a notch.
