soundblaster z with cm 690III confusion
24 Feb 2014
Thinking of getting a soundblaster z, main reason being my friends say they can hear my game sounds when I talk with PTT (currently using realtek onboard). Checked out the official page to see if my case would be ok with it for the front panel & one line stands out as confusing:
"This header follows the standard 2x5pin Intel HD Audio conform layout. It is not compatible with AC97 or Intel-compatible HD Front Panel Audio, as their pins are assigned differently."
Taken from this page :
http://support.creative.com/kb/ShowArticle.aspx?sid=14133
Manual for my case:
https://www.manualslib.com/manual/692669/Cooler-Master-Cm-690-Iii.html?page=5#manual
Now If I'm reading it right I should be ok for the front panel to work fine?
Not sure what the difference is between Intel HD Audio conform layout & Intel-compatible HD Front Panel Audio.
