Hey peeps,
I'm eyeing up a Gigabyte mATX board for my next build. I only have/want a single GPU, but I also have a Soundblaster Z, which is a 1x PCI-E device. These will be the only things in the PCI-E slots, so one will be unused.
1) can I plug the Soundblaster into the lower 16x slot? (this will give better airflow to the GPU)
2) will doing so cause the top GPU slot to drop to 8x?
3) does adding an M.2 SSD at a later date change anything, given that this will occupy another PCI-E lane?
(Also sly 4th question, is there any reason to believe the mATX version of this board is worse than its full ATX counterpart if you don't need the extra slots? I would like to shrink my rig, but not at the cost of knackering performance or overclocking potential.)
Thanks in advance!
Thanks in advance!
