Hey, the following is great. One of my colleagues took a sample home for the weekend and couldn't rave about it enough. He had a Bose one and said the difference was minimal so for the price difference it's a no-brainer.
FYI this will have a price drop on Wednesday in the "This Week Only" section. Can't tell you what the discount will be but it gives you a few days to check out some other reviews. Let me know if you want any more info.
Edifier Cinesound B7 - RMS 107W with Bluetooth @ £249.95 inc VAT
CineSound B7 provides a robust entertainment experience from a sophisticated home theatre system which uses a metre long soundbar coupled with an 8-inch subwoofer. The B7 comes versatile connectivity including Bluetooth 4.0 and Optical, coaxial, RCA Line-In, and 3.5mm auxiliary inputs along with a Smart Standby feature which kicks in after 10 minutes of inactivity.
Home Entertainment
Edifier has heightened your home theatre experience. Improving on the B3 soundbar, Edifier has created CineSound B7. Designed for your entertainment needs, the B7 Bluetooth soundbar is now accompanied with a subwoofer. It’s time to start watching all those movies on your to-do list.
Amplified Sound
Featuring an 8” subwoofer, Edifier’s B7 is introducing you to a new movie theatre experience from the comfort of your home. Designed with a 2-¾ inch aluminium diaphragm mid-range and ¾ inch silk dome, your audio will be boasting. Engineered with a tri-amplifying system to expand every sound from your TV or gaming system. Distortion is a thing of the past with the Digital Signal Processing and Dynamic Range Control built-in to the CineSound B7.
Thin And Sleek
Smooth and slim, the B7 Bluetooth soundbar is designed for elegance and entertainment. Its metre long design incorporates four speaker units and two tweeters for luxurious performance. A built-in smart feature knows when a movie or TV show finishes and after 10 minutes of inactivity sets Edifier’s B7 on standby.
Regulate Every Sound
Adjust the CineSound B7 to what your ears desire. With built-in controls on the soundbar, easily adjust volume, power and input selection or use the wireless remote. Edifier’s Bluetooth B7 also features three presets. With a simple click your sound is set for watching movies, the news or surround sound.
Multiple Connection Options
Designed for your home needs, easily connect any device with the versatile options the B7 provides. Its Bluetooth 4.0 capability allows you to connect any Bluetooth-enabled device to your speaker. Its 10-metre range lets you place the device anywhere you want without loosing connection. Connect multiple devices at the same time through optical, coaxial, AUX or through 2 RCA analogue audio inputs. You have the freedom to connect your TV and DVD at the same time.
Specifications:
- Total Power Output: RMS 16Wx2(Treble)+19Wx2(Mid-range and bass 75W)
- Signal to Noise Ratio: >85dBA
- Frequency Response: 48Hz~20KHz(±6dB)
- Input Sensitivity: Line in:700±50mV, AUX:550±50mV, AUX:550±50mV
- Input Type: Auxiliary/Line in/Coaxial/Optical/Bluetooth
- Bass Driver: 2 3/4"(700mm)
- Treble Driver: 3/4" (19mm) silk dome tweeter
- Subwoofer Driver: 8" (210mm)
- Speaker Dimensions: 1000x79x80mm
- Box Dimensions: 1085x645x351mm
Only £249.95 inc VAT.
ORDER NOW
