Hey guys
im currently building a map on Hammer, not a big map but sometimes when it gets to portal flow 1....2....3.. it crashes, it doesn't do it on every run it's very sporadic.
However i run a CPU temp in the back ground and see temps hitting the 81-83 digrees on 100% load, should i be concerned?
My case has enough airflow as i just brought a Zalman Z9 plus, the temp inside the case normally sits between 25-26 degrees.
it's a Standard Stock fan
System Specs are
Asus P67LE Chipset with a i5 2500k Cpu
4gigs of ram
750 Wat PSU
Gtx460
also on load in games for example Counter Strike the load temp is between 72-75, when in reality it should be nearer 50' Degrees.
Admin please could you repost this in cooling thread
Thanks
System Specs are
4gigs of ram
750 Wat PSU
Gtx460
Thanks
