source SDK: Hammer
25 Sep 2006
hi guys, wondering if anybody has a link to a tutorial on how to make the to of a wall arch shaped, or generally creating round walls etc etc?
thanks in advance
Benny.
You can split the wall up using the clip tool (select the line where you want it to seperate and click the clip tool twice more). Split it up into several equal pieces (say 16 units wide as an example) and then use the vertex manipulation tool to drag the down and create the arch.
