SP120 Heatsink mounting
5 Nov 2013
Ireland
Hi all,
Switching my build over to 540 air. I picked up a lot of SP120s for cheap enough as Ill be going custom loop within the next month but for time being I was going to replace the Noctua fans on the NHD14 cooler with 2 SP120s.
The Noctua fan clips wont fit onto the SP120s , the rubber holders (if thats what you call them) are too short to fit through the SP120 and out the other side in order to hold the metal clips.
Anyone have SP120 mounted on a big heatsink, can you tell me how you done it or if theres specific clips available to buy ?
Thanks
