SP120 PWM for H100i
28 Feb 2012
London, UK
Well since the fans are PWM, surely I should buy high performance fans since I can lower them to quiet edition fans if necessary, and even lower? It does work like that right?
Also, I can control the fans through Corsair Link when hooked up to the H100i right?
Yes, you can control the 4pin versions yes.
And yes, the performance ones turn into quiet if you limit their RPM.
I just don't see why you'd want em as the stock ones are almost similar. Waste of money.
I replaced the stocks ones instantly cause they make a terrible rattle. Screwed in tightly and i believe it comes from inside the motor.
Thanks for the info.
