Bummer, I like a low maintenance firewall but the SP2 firewall is VERY basic compared to Seagate Personal Firewall and Zonealarmkillsta said:Pretty sure the answer to both of those is no![]()
Dutch Guy said:Bummer, I like a low maintenance firewall but the SP2 firewall is VERY basic compared to Seagate Personal Firewall and Zonealarm
So it still has no outgoing control whatsoever, only incoming protection?
I thought the SP2 firewall was a lot better compared to the SP1 firewall?
) isn't really high maintenance and allows you to block all traffic on a single click. The only downside is it's no longer updated...Yeah, I have the old version of Sygate, I just thought that by using the Windows firewall it would be one less program that is running.Trigger said:Sygate (Well I hope you meant sygate- seagate make hard drives) isn't really high maintenance and allows you to block all traffic on a single click. The only downside is it's no longer updated...
Dutch Guy said:- Also is it possible to block a particular program?
