SP35P2 - Double slot graphics.
6 Jul 2004
All at sea
I am thinking about getting one of these with:
E8400
HIS 4850 IceQ 4 Turbo
2GB OCZ RAM
I am concerned about the double slot graphics obscuring the pci slot where I would want to put in the wireless card.
Any thoughts about the arrangements I could make please?
Also how noisy would you think this si going to be?
It will obscure the PCI slot. You could maybe use a USB wireless card?
Noise wise is subjective to the person! I think out of the box they are quite noisy as I have them sat on a desk beside me but there is plenty you can do to mod them, a lot of people end up changing the fans
Go on this website it'll perhaps answer your questions. I'm getting one of these and they rate it highly noise wise.techreport.com/articles.x/14034
My Leadtek 8800GTS 640mb only just fits width wise, if its any wider then forget it. Due to the bulk on the fan im tempted to say it wont fit.
If its any longer or wider than an 8800GTX it most probably wont go in.
