I have set this system up yesterday and it has been working all night. This morning, switched it on and there is no video (monitor in power saving mode)
System Details:
Shuttle SP35P2
CPU: Intel Core 2 Duo E8400
Memory: OCZ 4GB (4x1GB) PC2-6400C4
GFX: BFG 8800 GTS 512MB
HD: Seagate 500GB 32mb cache
OS: Windows Vista Ultimate 64bit
Initial Issues:
Had trouble with OCZ memory initially where Shuttle would hang at "shuttle screen" when booting up. Used only 2gb, Cleared CMOS and set voltage higher in bio and this seemed to have fixed it - 4gb works fine on higher voltage.
Had issue where shuttle would restart itself after switching off (either by me shutting down in windows or pressing the off button) After installing the sata dvd writer, it seemed to shut down correctly after.
After all this, it seemed to be working (Got vista patches, nvidia drivers) restarted / shutdown a few times.
This morning when switching it on, system does not post (no video) at all.
Fans and Lights on, no video.
Blue light at front blinks every 1-2 seconds
Orange light (HD?) at front blinks every 3-4 seconds
Shuttle fan is quiet, 8800GTS fan is loud (it was quiet yesterday) DVD rom still works.
Seagate makes a small seeking sound every 5-6 secs
-Removed all parts except Memory (1gb) tried all dimms an CPU - no change
-Tried all different combinations with 0/1/2 gb ram on all dimms - no change
-Reset cmos button - no change
-Took battery out and reset cmos - no change
-Tried VGA adapter on 8800GTS - no change
-Tried PCI graphics card (vga) - no change
- Removed CPU - the 92mm fan is much louder, no blue lights and no orange lights at front.
At this point i do not know what to do. Do i RMA the shuttle or the CPU? or could it be the memory?
System Details:
Shuttle SP35P2
Initial Issues:
