space in the unit??
22 Aug 2011
Hi,
If I have the following set up will I have space in the unit for this ....
Crucial Ballistix Sport 12GB (3x4GB) DDR3 PC3-12800C10 1600MHz Triple Channel Kit (BL3KIT51264BA160A)
or will I have to limit myself to this?......
Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (BL2KIT51264BA160A)
1 x Intel Core i5-2300 2.80GHz (Sandybridge) Socket LGA1155 Processor - Retail £142.99
1 x Microsoft Windows 7 Bundle - Home Premium 64 Bit £68.40
1 x MSI H61M-P23 Intel H61 (Socket 1155) DDR3 Motherboard **B3 REVISION** £44.99
1 x Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (BL2KIT51264BA160A) £43.19
1 x Cooler Master Elite 334 Midi Case - Black £30.98
1 x Lepa N-Series 400W Power Supply £25.98
1 x LiteOn IHAS124-19 24x DVD±RW SATA ReWriter (Black) - OEM £16.99
Thanks.
Bit new to this and the lingo!.... is there one with 3 ram slots so I can get more for my money?
The 12GB and 8GB are the same price at the mo so it seems stupid not to take advantage of it.
Cheers.
I have just placed the order and been told that one item is out of stock and should choose another.
LiteOn IHAS124-19 24x DVDąRW SATA ReWriter (Black) - OEM 1 £14.16
Any suggestions.
Erm....not sure about hdd!
Do you really need >8GB for the machine?
That system will gain nothing from going from dual channel to triple channel even if you swapped mobos and cpu to make it possible (same goes for just about any system btw, not knocking yours).
