Space limited build
18 Oct 2013
Hi all, I've had a look through forums but can't see anything which would apply specifically.
My 1st problem is I'm very lmited as to the space in which I can place a PC. Almost no room to the rear of standard ATX case and very limited clearance to the sides. I have some room vertically and the front would be open which brings me to problem no 2. 7 Cats & 1 Dog in the house so the air inside is usually a thick fug of discarded pet hair which as you can imagine clogs fans up fairly rapidly.
So what I'm looking for would be a build which would require the least possible air intake and a case where my air flow is basically bottom to top with space behind mbo to hide cabling to maximise air. I can budget £600 - £700. Optical drives etc I can scavenge and I won't need to include an OS in the price. To be used for some gaming but nothing too taxing graphically. SSD for the OS and a 1Tb hard drive.
Not built anything for a good few years but I'm assuming Intel still run cooler than AMD? If so I'd be looking at Haswell for some futureproofing so I can upgrade if I ever get some space. If watercooling is the way to go then some kind of self contained unit would be necessary given my general clumisness.
Looking forward to your help
Cheers
