Spacious Case for 240/360mm Rad
19 Oct 2002
Looking for a case for a new project. I like spacious. I like having room to work around my components and not having the interior look cluttered. That said i don't want it to be a void of static airflow.
I'm planning on water cooling now or in the very near future and forsee me using a 360mm rad for future heat requirements. I'd prefer the rad to be mounted internally either in the top or front of the case. If it mounts in the front then I still need at LEAST 5 free 3.5" drive bays and 2 5.25 bays free.
I currently have a CM stacker original and decided it's time for a change. Removable motherboard tray would be nice as would the easy access block mounting hole in the newer CM cases.
Weight isn't a problem and neither is size :-)
So...... any suggestions?
I too have been looking at the coolmaster, its works ok on a non-water system right (non-water), and its obviously ATX compatible?
Just want to make sure before i order.
Just to give you an idea of the size here is a standard ATX mobo in it:
The HAF is great for Air cooling due to its High CFM but low RPM 230mm fans, as shown here:
http://www.bit-tech.net/hardware/2008/10/16/cooler-master-haf-932/4
Here is a pic of a triple and single Rad installed internally:
That looks awesome, think I will see a big difference between my midi case and a new full size one!
I'm really tempted to get the HAF now but that '840' is holding me back!
looking at the 840 the cable manangement doesn't seem to be as tidy. With the removable tray they have cut away all the lower section of plating by the PSU so you can't hide the long PSU cables.
Seems almost a step backwards
