Span on 280GTX SLI?
9 Dec 2006
@ManCave
i want the start bar to go across both my monitors, but in nvidia control panel it doesn't give me the span option :(
Right click on the desktop and then choose Personalise or Properties depending on your OS. Select Settings and there should be a box on that screen to extend your desktop to a second monitor. Tick that and you should be good to go.
I second the ultramon, I've been using it for *years*. I can't believe they've not added something like this into Windows yet - it makes multi-display setups so more usable!
