hey guys,
I have a watercooled system, coolriver deluxe but with different pump and not using the stock fan.
I have 2 akasa amber fans either side of the 120mm radiator blowing the air out of the case. I have an 80mm fan at the front sucking air in. I have a spare akasa amber 120mm. I have tried attaching it to the radiator but didnt really make any differnce. At the moment it is just in the middle of case not really doing anything.
Where should i position it to get maximum effect? Should i have it close up to the cpu, blowing on that waterblock?
It just seems a shame to waste the fan, if i can shave of 1c i will be happy!!
cable ties here i come!
also when we measure the temp and we say idle, does that mean basically nothing going at all, just your computer ticking over? And when you say load is that just normal apps or gaming?
Thanks you lot!!
Thanks you lot!!
