Spare screws for Lian Li V1000
17 Jun 2003
Scotland
Can i get spare screws for this case ? I need 8 HDD mounting screws for a Lian Li V1000.Just bought one second hand, but it has no HDD mounting screws with it,no other screws seem to fit
Anyone help here please ?
Cheers,
Rob
Are they just normal Mounting screws or are they specialised fit for the Lian - Li. If they are standard I could post you a few as I have a box full.
Herminator said:
They're different, they have a smooth section on them which slides into the rails on hdd cages.
I have tagged some general spares onto my air shipment from lian li that will be arriving with the next few days. If you sit the posting costs I will send to you.
I'll be more than happy to pay postage for the mounting screws mate :D
That's very good of you.I have mailed your trust address, to sort out postage costs etc.
Many thanks,
Rob
Brilliant Yewen !! Thanks for the help.
It will just have to sit in the box a while longer,desperate to get it up & running :D
Fatboy,can you drop me a mail at my trust address & i'll be able to sort out postage,the mail i sent to you was undelivered
Rob
That is what you are after, hope thats useful some way. :)
