Spark plug threads
Man of Honour
Man of Honour
3 May 2004
Kapitalist Republik of Surrey
Does anyone know the pitch for 10mm and 14mm spark plug threads? Looking to buy a tap for each, handy if I can use my existing NGK BP6ES plugs which are 14mm.
14 x 1.25 for ngk bp6es iirc, i run them but aint checked in a while.
taps are bloody expensive in that size, i found thread chasers where a third of the price and do nearly the same job.
Will they do a new thread in steel though? I just dug out one of my 10mm plugs and it looks like it's a shade over 1mm, so probably 1.25mm. Just going to stick a vernier on it to check...
they wont do it through brand new steel, but if there was thread there then it will fix it, i used one to sort my lambda sensor mount in exhaust.
otherwise if your drilling a new hole your needing a tap, and looking at £25 for one!
