Spatial puzzle
11 Sep 2012
I know it seems like a odd question, especially given we are now in 2012 but...
Is it possible, if you have a BTX case, if you rotate it forward 180 degrees when the back of the board is facing you (opposite of the side that comes off) so its upside down, then get an atx board and rotate it 180 degrees sideways, it will fit inside your case and the pcie slots can be used for graphics cards.
Um hope someone understands :D
