just got an aopen xcube, it has an intel 865 mobo with ac97 sound
when i plug into the line in from my freeview box i get sound like i should but when i use the optical from the box there is nothing, checked the box settings and the optical signal is set , on the pc settings under spdif in it says 48khz, when i remove the cable i can see it drop to nothing then put it back in it says 48khz again so the signal is there but no sound comes out, in the volume properties playback and recording spdif is selected and not muted and the volume is turned up
