spe . me dads comp
8 May 2011
Right my dad is hinting at he wants a desktop to for download and light gaming everything needed except monitor less than £250 if possible needs to run games with no lag on low to medium for next few years :)
It is going to be extremely difficult, if not impossible to build a gaming PC for under £250.
This is the lowest I've managed to get it, but I don't even know if this is going to play the latest games smoothly, although you should able to play some of the less graphic intensive games with no lag:
YOUR BASKET
1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-00599) £79.99
1 x Antec High Current Gamer 620W Power Supply £49.99
1 x AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3) - Retail £40.79
1 x Kingston HyperX Blu 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel Kit (KHX1333C9D3B1K2/4G) £34.99
1 x Samsung SpinPoint F3 500GB SATA-II 16MB Cache - OEM (HD502HJ) £32.99
1 x MSI GF615M-P33 GeForce 6150SE (Socket AM3) DDR3 Motherboard £32.99
1 x MSI ATI Radeon HD 5450 1024MB GDDR3 PCI-Express Graphics Card £29.99
1 x Cooler Master Elite 342 Case - Black £27.98
1 x OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £14.99
Total : £358.80 (includes shipping : £11.75).
Unfortunately mate, your not going to get very far with a budget of £250. You may be able to get a base unit for general office work / downloading but don't be expecting to play games with the onboard GPU, but consider adding a reasonable one in at a later date when funds allow.
Do you need a copy of Windows 7? If your student you may be able to get it cheaper.
How about something along the lines of the following for the base unit.
YOUR BASKET
1 x Cooler Master Elite 430 Windowed Case - Black (with 500w Elite Power PSU) £64.99
1 x AMD Athlon II X3 Tri Core 450 3.20GHz (Socket AM3) - Retail £59.99
1 x Asus M4A78LT-M 760G (Socket AM3) DDR3 Motherboard £49.99
1 x Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) £33.59
1 x Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache - OEM (WD5000AAKX) £29.99
1 x Sony Optiarc AD-5260S 24x DVD±RW SATA ReWriter (Black) - OEM £15.98
Total : £266.53 (includes shipping : £10.00).
Save up and get the graphics card later on. The 5450 won't play games so best to save up for something like at Radeon HD5830 which can be had for around the £80 mark. Paying a bit more for the Tri-Core over the dual core should "future-proof" the system a bit and you can add in a Phenom II X4 or X6 in a couple of years.
Worth shopping around and looking for special deals and perhaps consider second hand market too.
If you don't need an OS and can give him your 5670, the choice is suddenly a lot easier.
Coolermaster 430 Case w/PSU £65
Xenon AMD Phenom II X4 840 3.20GHz Bundle £165
Total £230, sorted.
YOUR BASKET
Scraping the bottom of the barrel, but this actually isn't bad :)
Can save £16 if you can salvage an optical drive, even an old IDE one.
