Hi there guys I recently got a Fisher Ca-224 amp and monitor audio br1 from a carboot sale from two different sellers. I paid 30 pounds is total for the set. However I haven't realised that the speakers are 6ohm whereas the amp is rated at 8 ohm only 2x35 rms.
I connected them up together and at 20% volume they sound impresive and loud enough with no distortion or hissing. However I'm worried that through not matching the impedancesearch, I will break either or both.
Any advise would be appreciated
Thanks Sam
Fisher CA-224
Integrated Stereo Amplifier 1986
Specifications
Power output: 35 watts per channel into 8Ω (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.5%
Damping factor: 20
Input sensitivity: 2.5mV (MM), 150mV (line)
Signal to noise ratio: 68dB (MM), 85dB (line)
Dimensions: 400 x 91 x 202mm
Weight: 4.1kg
Year: 1986
Thanks Sam
Fisher CA-224
Specifications
Damping factor: 20
Weight: 4.1kg
Year: 1986
