After reading AV Forums extensively I went with B&Q regular speaker cable on their recommendation.
Works and sounds nice with my amp and speakers.
I think I'll grab some next time I'm down there.. at least it won't cost an arm and a leg!
Van Damme Blue is usually recommended as a reasonably priced ceiling, but personally I'd get any decently built 2x4mm2 cable, which you can usually get on a reel for about £25.
im not sure to go banana plugs or not, wiring up a 7.1 amp is a bit of a nightmare and im intending to bury the cabling in the floor. i would need 38 of them as im bi-wiring the LCR and single wiring the surround and surround rears. unfortunately i cant really use the current wiring i have. oh well i think i will ebay all my spare wiring. i have loads of it.
for movies maybe but audio might be different. do you do 5.1/71 stereo for music or pro-logic music setting or just 2.0 stereo?
same length as if not you can get echoes in sound. the longer cable takes a fraction of a second longer to reach its destination.
my denon amp actually sorts out this issue as do most decent amps.
If im honest I dont know a great deal about audio/video, I am trying to learn though but this is what I got at the moment..
First thing you will learn when you start reading.
The internet and the general press is full of certain people, whom i nickname the "believers"
The believers firmly and truely believe that the amount you spend on your cable is proportional to how good the sound or picture is. They are adament that they can tell the difference between a cheap and expensive cable, even HDMI ones.
These people would have you spending thousands on cables and will quite happily talk for ages about how amazing their setup sounds now they put their speakers on these super amazing £1000 stands.
For normal people, any cable will do, and you can put your speakers anywhere you like. Take everything you read with a pinch of salt, and try and see if you can find someway of testing the differences yourself.
When i was choosing my home cinema setup,i drove myself mad trying to sift through the advice as to whether you needed expensive cable or not, what speakers were good, which were bad, how to mount them etc... In the end i decided i didn't need to worry about stuff and just bought some speakers and some cable, and couldn't be happier with the choice. You may well be a believer too, but make sure you end up one through your own choices and experiences, not from reading stuff from others.
Just spent £1200 on cable. I can not tell the difference between my £50 a meter Chord Epic, and some cheap 60p a meter unbranded cable. OH GOD WHY
