Speaker Cables?
3 Dec 2004
Hello,
I have pair of Aegos and im using the cables that came with them to connect the speakers together + the sub. They are reaally long and im trying to cut down on the clutter.
It only needs to be about 1m long - i will need 2 as there are 2 speakers :)
Regards,
If your connections are the spring clip sort, or like those screw ones that you get on a hi-fi and speakers, you'll only need to cut them to length and strip the end bit. If they have a 'plug' to plug speaker to sub, I wouldn't bother, and get some cable ties.
They appear to have spring clip connectors on the sub unit. You just need scissors to cut the wire and carefully strip the insulation of the cut end :)
