Speaker dust mesh cleaning
12 Mar 2013
Grimsby UK
Very simple question. I have a soundbar with the speaker dust mesh that's common over the front. This does not remove
My lovely daughter has got what appears to be yoghurt in it (only small amount). But also the dust needs a good clean really.
What's the best way to clean this material as it seems thin
Compressed air for the dust. Light wiping with an all purpose cleaner and a microfibre cloth for the yogurt.
I use the brush attachment on the hose extension of our Dyson to clean my speaker grills. The bristles agigtate the dust particles and then it gets sucked straight down the hose.
