Speaker Extendable Bracket/Stand
26 Feb 2013
Hi all,
I'm purchasing a cheap all in one home cinema for another room soon, as you know the satellite speakers are quite light and I don't have much space for a stand beside the TV stand I've got below.
Anyone know of any solution/method I can use to have my speakers beside the TV?
Is there some sort of bracket that I can clip/tighten onto the metal framework of the TV Stand then I can attach my Speakers to it?
All in one kit speakers are so light that a bit of Bluetac or Velcro would probably do. Lol
...or have them float in mid-air using a single helium filled baloon on each :p
Have you measured if the TV completely goes edge to edge on your stand, perhaps the speakers may just sit on the edges?
