- 28 Jan 2005
- Southport
Hi all,
Im going to upgrade my speakers in my focus. Ive got the following head unit:
http://caraudiosecurity.com/shop/product/products_id/10210.html
Im looking at components and ive found two but cant choose between them. These are the two sets:
Alpine: http://caraudiosecurity.com/shop/product/products_id/2849.html
Hertz: http://caraudiosecurity.com/shop/product/products_id/8399.html
With the hertz i will need adaptors to fit them and the alpine I wont. I wont be useing and amp as im not wanting to spend that much. I have a 10" Fli active sub in the boot.
Which would you recommend that will work better with my headunit without an amp?
Thanks for your help.
