Heya
My current set up is 10 cm caliber speakers in the front and 17 components in the back
I got a 2 chanel MTX amp running a 10" MTX sub and i also got a 4 channel MTX amp which is curretly just running the rears and it would be to much power for the fronts,
Im happy with my amps, Sub and my head unit atm but i want to change both my front and rear speakers.
I can fit a set of 13 components in the front and 17's in the back but all these different speakers confuse me.
I was looking through car audio direct and was baffled about which to buy.
I can afford to spend around £200 for the rears and £200 for the fronts maybe a bit more.
You guys got any recomendations, I like a lot of bassy music such as r&b and happy hardcore, so performace from the speakers and reliablilty is on the top of my list atnm.
Thanks
Chris
Thanks
Chris
