Hi,
In my car at the moment all im running is 2 3.5" Infinity speakers in the dash so as you can imagine the sound is some what limited.
I have a parcel shelf with some 15cm ish speakers and im buying some front door pods to accommodate 17cm speakers.
Would it be best to just get some 17cm component speakers and run them along with the 3.5" and do away with the rear ones completely?
My head unit is a JVC KD-G722 (USB jobby) btw.
