Speaker Recommendations?
29 Jun 2011
Hi All,
I've been looking for a bluetooth speaker I can connect to my S6 to give it a bit more volume. I use my phone to listen to podcasts on youtube while cooking/in the shower etc but my S6's speaker is not quite loud enough.
I've looked at the likes of Sonos play 1 but at £190 it's probably overkill for what I'm looking for.
Can anyone recommend anything I've probably overlooked? I'm happy to buy a play 1 but I wanted to consider the other options first.
Cheers
The JBL Flip and Charge are quite good. I also like the UE Boom 2 although I have not used one yet.
If you want something a bit smaller the JBL Clip 2 is also good.
All of them are also waterproof
Monitor Audio Airstream S150 is a good bet. Also has aptX for better sound over bluetooth, but also has a line in.
Could always get an Echo too, that'll handle the podcasts without having to use your phone.
