Speaker Spec
1 Oct 2008
Designing Buildings
Hi,
I'm looking to improve my speakers on my new pc. at the moment I've got some old harmen / kardon stereo speakers from an old dell pc and quite frankly they dont do the job.
I'm using a Gigabyte GA-X48T-DQ6 Intel X48 (Socket 775) PCI-Express DDR3 Motherboard onboard audio. whats the best I can expect using just that and also whats a good speaker / sound card combo should i decide to upgrade the sound spec as well.
:D
EDIT : the onboard audio is Audio Realtek ALC889A codec High Definition Audio 2/4/5.1/7.1-channel
I was planning on getting something like the Logitech Z-5500 THX Certified 5.1 Speaker System (970115-0120) as sold by OC. is it ok just to plug into my mobo or would an additional sound card be preferrable? Thats really what I'm asking.:confused:
An additional sound card would be preferrable, but they will still sound very good on normal onboard sound.
I think the Z5500's have a digital input, so if you are using that an external soundcard will make absolutely no difference to sound quality.
