Speaker switch box
5 Nov 2010
Hertfordshire
Looking for a nice black (preferably alu) speaker switch box. I have separate speakers for different uses and music types so i don't want to run them at the same time, just switch between the two.
Anybody know of any? I was thinking something like the QED SS22 2 WAY Switch Box?
Any ideas or experiences?
If your amp does not have an A / B, A + B switch on it, then that would do the job perfectly. Doubt there is a great deal of choice and they will all do exactly the same thing anyhow. If you can solder, you can make one using a small black anodised alu case, 2 high power switches, cable and some binding posts. (you get exactly what you want by making it yourself)
Nope, my receiver/amp (Marantz PM6010 OSE) only has a single set of speaker binding posts, hence why i am asking...
You have however come up with a great idea.... it's a simple switching box, so could just DIY. Good plan Kei!
