Would my Ford Fiesta MK5 2002 be able to cope with powering 2 x 160W front speakers that i would like to upgrade to? I have heard that you have to be careful sometimes particually with amps and subs as they can easily drain the car's battery down to flat etc. I am looking at a pair of Sony, JVC or Kenwood 140W - 160W peak / 35W rated 5.25" (13cm) size speakers to upgrade to and before i upgrade to them i just want to know if it is suitable to use them without them draining the battery? By the way i will not be using any amps or subs to power the speakers as i have got a pair of special Ford connection to Coaxial adapters so i can easily connect up to the speakers without any modding or soldering etc. I will also be upgrading the rear speakers to some 5.25" (13cm) in the near future too. Lastly can anyone explain the difference between the peak and the rated power?
Thanks guys - Liam
Thanks guys - Liam
