Speaker upgrade
22 Mar 2014
Plymouth
Hi guys for the last 7 years or so I have owned Bose companion 3 Serie II and I have been highly satisfied with the way they sound. I have to say they were worth every penny I paid for them (270 pounds).
Currently, I'm looking to buy myself a new speakers pair of speakers. Any ideas how much it would cost to have a significant upgrade. At the moment I do not have a budget but it can't be more than 600 pounds.
Well for £600, you can get some very good speakers. I know some people do like Bose products, and I don't wish to offend, so I'll just say that I find them to be overpriced for the sound quality you get. They make lifestyle products which are clean, simple, nice looking designs, which is at the forefront of people's thoughts when they are considering Bose; rather than first looking at what should be the most important part in a sound system, the sound quality.
The best thing I think you can do, would be to go to your nearest Richer Sounds store, or any other that may be local to you, and have a listen to speakers that will fall within your budget; taking the price of the amplifier into consideration as well. Even if you don't buy anything, you will get an idea of what you are looking for. Different brands of speakers have different sound signatures, and will appeal to different people.
Of course, if you live somewhere where traveling to an audio store is a long distance (It is for me. 60 miles to the nearest RS store), then you'll have to on reviews and comments alone. I'm sure recommendations can be made for you to consider, if that is the case.
Marsman thank you for your reply. I will go to the richer sound store and have a listen. Any recommendations on what brand makes good speakers?
My main concern is the amp itself as I don't know anything about them. I can tell the differences in sound but have no idea about internals and their quality.
Another option is studio monitor speakers. They tend to perform better than HiFi speakers on a desk because they are designed for close listening and perform well at lower volumes.
HiFi speakers still will sound good when used on a desk, but their ideal placement tends to be when they are given more open space with the listener sat further back. They generally sound better when turned up and can fill the room with sound, which is certainly more comfortable when you're sat back a few feet, rather than sat close getting your ears blasted with louder volume. :D
One of the advantages of studio monitor over HiFi speakers, is that active/powered ones (most common) have the amplifier/s built in. HiFi speakers being passive need an external amp. Integrated stereo amps are quite large slabs of metal and electronics, so for some people especially using them on a desk, space might be a bit limited. Some people get round that by using a small T amp, which is a great way to use passive speakers on a desk with no room for a large amp. They are best paired with budget speakers though. If you're spending a few hundred on speakers, they really deserve a decent full size amp.
Two very good but well within budget studio monitors are; JBL LSR305 and Tannoy Reveal 502 for around £250 and £350.
You could easily spend more though on something like a pair of Adam's. They can get expensive pretty fast though.
For HiFi speaker brands; Wharfedale, Mission, Mordaunt Short and Q Acoustics produce very good speakers in the region of £100-£200. Monitor Audio, KEF and DALI generally sit a bit higher up and have a wider range of offerings, from budget to a bit more expensive. Bowers and Wilkins (B&W) are a bit more expensive again. All produce very good speakers though in the price categories they sit in.
Denon, Marantz, Cambridge Audio, NAD, Yamaha, Pioneer and TEAC all make decent amplifiers. £130-£200 will buy a good budget one.
There is no right or wrong choice when it comes to which type of speaker to go for; as with nearly all things to do with audio, it's about personal preference. Some people prefer HiFi speakers because they tend to have a more coloured sound compared to studio monitor speakers, which are designed to be more neutral. Some people prefer more neutral sound, whereas others find studio monitor speakers lack excitement.
Without listening to both types, it's hard to know which you will likely prefer; but it's a lot easier to go and have a HiFi speaker demo though. Studio monitor speakers are probably only sold in specialist music stores, which are fewer and further between compared to stores like Richer Sounds, etc.
Nice post Marsman.. following on from that I can recommend the Adam F5 studio monitors as I have a pair myself. They are a fairly compact size, with the usual controls and connections you can expect from a studio monitor.
As for sound it is easy to forget how good they are, as you get accustomed to them as with anything. If you have the right room acoustics then the bass could also be more than ample.
Some other options which I haven't tried myself are:
focal alpha 50
yamaha msp5
SamyBoy13 if your buying from richer sound make sure its what you want i almost bought some BT3s from them till i got to the till and asked what happens if they are not right with my set up or i do not like them. they said any returns have a handling return fee of 15% of the price. so returning stuff could cost you if you change your mind. i left my purchase at the till and left the shop.
i understand why they do it, but its over priced for a return fee IMHO they should change their policy.
Hi All
Happy new year in advance. Please suggest me a good sound system with Bluetooth/Wifi for classical music/songs from Mobile/Laptop/TV. Budget max-500 GBP.
Thanks
Harry
I'm running Monitor Audio Bronze 1s with a centre and sub, a grand total of sub £600. Honestly I cannot fault them. These however may be too big in comparison to the Bose setup.
