- 20 Jul 2009
- The bleak North East arm pit of Britain
Hello
This weekend we are launching a savings on the headset and speaker range here at OcUK.
There are only a selected few lines with the 48 hours discount as well as some of the great deals featured on This Week Only.
Take a look below as there are some great savings to be had!
Edifier R1600T Studio Plus 2.0 Monitors @ £62.99 inc VAT
The Edifier R1600T Plus is a professional low-noise amplifier with all wood enclosure. The high performance crossover provides superior coverage while magnetic shielding prevents interference. The 5-inch bass driver is designed using a composite cone structure for a truly balanced acoustic. Built-in, side-mounted controls mean volume, treble and bass are at your fingertips. Dual RCA inputs allow connection of two additional devices for maximum flexibility in your set-up.
- Professional low-noise amplifier coupled with high performance crossover.
- 4.5inch bass driver - designed using a composite cone structure for a balanced acoustic.
- Silk diaphragm 18 mm tweeter with aluminum phase plug.
- Side mounted rotary volume, bass and treble controls.
- All wood enclosure.
- Power Output: RMS 2 × 16W
- Signal to noise ratio: 85 dBA
- Distortion: 0.1%
- Bass unit: 5 inch (120mm), magnetically shielded, 6ohm
- Tweeter unit: 18mm silk dome tweeter, magnetically shielded, 4 ohm
- Input impedance: 10K ohm
- Input sensitivity: 550 mV ± 50 mV.
- What's in the box:
- 1 x Active speaker
- 1 x Passive speaker
- 1 x 3.5mm to RCA connector cable
- Audio connecting cable
- User manual
- Dimensions: 152(W) x 252(H) x 228(D) (mm)
** boxes opened to include UK power connector, 100% new **
Was £69.99 Inc. VAT
Only £62.99 inc VAT.
ORDER NOW
M-Audio Studiophile AV40 (MK II) Speakers @ £89.99 inc VAT
The compact Studiophile AV 40 powered speakers deliver the same proven M-Audio technology favored by top producers, recording engineers and musicians around the world.
- 4" polypropylene-coated woofers > tight, accurate bass
- 3/4" ferrofluid-cooled silk dome tweeters > clear, smooth highs
- Optimage iii tweeter wave guides > precision imaging for balanced stereo field
- 20-watt-per-channel amplifier with class a/b
- Type: two-way desktop reference monitor
- Low-frequency driver: 4" diameter, magnetically shielded and curved cone with high-temperature voice coil
- High-frequency driver: 1" diameter, magnetically shielded silk dome tweeter
- Frequency response: 85hz
Was £98.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Edifier S550 5.1 Speakers 280 W RMS Sound System @ £299.99 inc VAT
280 Watts of power drive this luxurious 5.1 system. Coupled with a passive radiator the massive 10" subwoofer driver provides a room-filling 120W of deep bass. A multi-functional 2.5" LCD display wired controller provides all the control any user needs.
Features
- Luxurious 5.1 speaker system with 10 inch subwoofer
- Wooden MDF housing for all speakers
- Passive radiator on both sides on the subwoofer to exaggerate bass performance
- Magnetically shielded drivers for all speakers
- Switchable dual input ports for both 5.1 channel and stereo inputs
- Multifunctional wired controller with 2.5 inch LCD display (dimmer included)
- Headphone output on wired remote controller
- Master volume controls both speaker output and headphone output
- Volume booster for extra power output
- Separate bass and treble adjustments
- Multifunctional wireless remote controller included
Specifications
- Power output: RMS 32Wx5 + 120W (THD=10%)
- Signal to noise ratio (amplifier): >=85dBA
- Input sensitivity: 5.1Ch: L/R: 480mV +/- 50mV SW: 175mV +/- 30mV Stereo: L/R: 520mV +/- 50mV SW: 200mV +/- 30mV
- Frequency response: L/R: 140Hz ~ 20kHz SW: 20Hz ~ 133Hz
- Bass Unit: 10", magnetically shielded speaker driver, 4Ohm.
- Satellite Unit: Mid-range ---- FR/FL/SR/SL: 3 1?2", magnetically shielded, 8Ohm C: 3 1?2", magnetically shielded, 4Ohm Tweeter unit--- 1" silk dome tweeter, magnetically shielded, 6Ohm
- Dimension: Subwoofer: 14.4"x15.6"x19.2" (367x397x489mm) WxHxD, Front speaker: 4.6"x8"x6.3" (116x203x160mm) WxHxD, Center speaker: 12.4"x4.6"x6.2" (316x117x157mm) WxHxD
- Gross Weight: approximately 82.5Lbs (37.4kg)
- Power Input: 220V-240V ~, 50/60Hz
** boxes opened to include UK power cable, 100% new **
Was £329.99 Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Corsair Gaming Audio Series SP2200 2.1 PC Speaker System - 46 Watts RMS @ £37.49 inc VAT
The SP2200 is designed for gamers and media enthusiasts who want a powerful, compact 2.1 speaker system that doesn’t take a lot of space. 46 Watts of total power (measured via the FTC “RMS” method), with 30 Watts dedicated to the 6” subwoofer, ensure room-shaking bass and clean, crisp audio reproduction at any volume level. Excellent stereo imaging with a generous “sweet spot” ensure a competitive advantage in games and realistic music and movie audio.
The SP2200 is easy to set up, and easy to use. Controls are up front where you need them, and flexible connection options allow you to connect up to three audio sources at once.
- 46 Watts RMS continuous power delivery for room-filling sound and clean, crisp audio reproduction
- 30 Watt subwoofer with 6” driver for serious bass performance
- Compact satellites with 3” drivers provide detailed audio reproduction without taking lots of desk space
- Excellent stereo imaging with a generous “sweet spot”
Specifications:
- Frequency response of 40Hz – 20kHz +/5 5dB, -10dB @ 35Hz
- 46 Watts total power (measured via FTC “RMS” method)
- Subwoofer: 6” (15.24cm) side-firing, ported subwoofer suitable for desk or floor placement
- Subwoofer: 30 Watts (measured via FTC “RMS” method)
- Subwoofer: Subwoofer enclosure dimensions: 9.1” x 9.9” x 7.1” (23.1cm x 25.2cm x 18cm)
- Satellites: 2” (5cm) drivers
- Satellites: Volume and subwoofer output controls integrated in right satellite
- Satellites: Up-front auxiliary input and headphone output
- Satellites: 8 Watts per satellite (measured via FTC “RMS” method)
- Satellites: Satellite enclosure dimensions: 5” x 3.6” x 5.6” (12.7cm x 9.1cm x 14.2cm)
- Satellites: PC input on subwoofer
- I/O and Controls: Three inputs for maximum flexibility: 3.5mm stereo PC input, RCA stereo auxiliary input for gaming consoles, and a 3.5mm stereo auxiliary input on the right satellite for MP3 players
- I/O and Controls: 3.5mm headphone output
- I/O and Controls: Main volume and subwoofer output control dials on the right satellite
- Package Contents: x1 subwoofer, x2 satellites, Power cable, User Guide
- Retail box dimensions: 12.8” L x 11.5” W x 11” H (32.5cm L x 29.3cm W x 28cm H)
- Weight: 11.17 lb (5 kg)
Was £49.99 Inc. VAT
Only £37.49 inc VAT.
ORDER NOW
Acoustic Energy Aego M 2.1 Speaker System - White @ £119.99 inc VAT
The Aego M-System builds on the strengths of the award winning Aego 2, offering a pair of heavy-alloy satellite speakers and a compact subwoofer for a full range sound that embodies AE’s sound quality principles. The sleekly styled satellites have smoother treble and a funky rounded design while potent amplifiers are built into the subwoofer to drive all three loudspeakers. The package gives room-filling sound from devices like the iPod™, PSP™ or MP3 mobile phones. With just one cable the M-System turns any personal music device into the heart of a home entertainment system. In the living room, in the bedroom, away at college or simply for a spontaneous party, the M-System delivers a big sound form the smallest devices. Better still, the M-System’s gorgeous looks, high quality sound and plug and play simplicity won’t cost a fortune as it remains just as affordable as the best selling AE Aego 2.
- Easy to setup and use
- Hi-fidelity, high volume sound
- Instant home entertainment
- Big hi-fi sound from the smallest devices
- Outstanding value for money
- Inputs: 3 x RCA Phono - Line level, 1 x Stereo Mini jack - Line level
- Outputs: 3 x Speaker terminals
- Controls: 1 x Volume / Power pot, 1 x Bass switch (3 Position), 1 x Centre input switch (2 Position)
- Power ratings: 120V Model - 120V @ 60Hz; 80VA, 240V Model - 240V @ 50Hz; 80VA, 90 Watts RMS total system power rating
- Frequency response: Sub is 50Hz-250Hz and the satellites are 250Hz-16KHz
- Dimensions: Sub Woofer - 265 x 190 x 350mm, Satellites - 68mm x 103mm x 90mm
- Weight: 9 Kg
Was £123.98 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Acoustic Energy Aego M 2.1 Speaker System - Black @ £119.99 inc VAT
- Weight: 9 Kg
ORDER NOW
Creative Fatal1ty HS-800 Gaming Headset (51MZ0310AA001) @ £23.39 inc VAT
Creative's Fatal1ty Gamer Headset provides power, precision and comfort for the serious gamer. The ergonomic, lightweight design, with padded velvet earpieces and headband, ensures a comfortable fit during extended gaming sessions. Weapons, positional cues and environmental audio effects sound fantastic through the high-quality drivers, with excellent bass response for powerful explosions. The noise-cancelling microphone transmits voice commands clearly to other team members, and it can be detached for easy storage or to use the headset like regular headphones. In the heat of battle this is the headset that won't leave people stranded - and that's why Johnathan 'Fatal1ty' Wendel, the world's best known pro gamer, uses it.
- Ergonomically designed and acoustically tuned for gaming.
- Padded headband and earpieces for ambient noise exclusion and comfort during long gaming sessions.
- Swivel joint earpiece design adapts to every user.
- Detachable and adjustable noise-cancelling microphone.
- In-line external volume control with microphone on/off.
- Excellent response for voice communications and dynamic in-game audio, with extended bass response for high-impact explosions.
Was £24.99 Inc. VAT
Only £23.39 inc VAT.
ORDER NOW
Corsair Gaming Audio Series HS1A Analogue Headset @ £28.74 inc VAT
The Gaming Audio Series HS1 Gaming Headset is designed for gamers who are serious about audio. Massive 50mm driversdeliver serious punch, without sacrificing the sparkling sound quality you need for music and movies. Extra-large, extra-deep memory foam earpads provide a reliable, custom fit that’s so comfortable, you might forget you’re wearing them.
- Massive 50mm drivers for high-quality audio reproduction
- Detailed audio reproduction with clean, accurate bass and sparkling clarity in mids and highs
- Circumaural, closed-back earcups for superior noise isolation
- Memory foam earpads provide a custom fit that won’t weigh you down
- Includes two sets of earpads to customize your comfort – your choice of microfiber or synthetic leather
- Connectivity: 3.5mm jacks for ear piece and mic
- 2 Years Warranty
Was £29.99 Inc. VAT
Only £28.74 inc VAT.
ORDER NOW
Corsair Vengeance 1300 Professional Gaming Headset @ £59.99 inc VAT
If you have a high-end sound card, the Vengeance 1300 will do it justice. If your audio card has CMSS™-3D or a similar 3D audio system, you’ll hear the subtle midband positional cues that you need to enjoy accurate 3D audio and play your best. Is your enemy behind you and to the left, or to the right? Are they behind a wall, or do they have you in their crosshairs? Gaming sound designers work hard to make audio sound great, and your high-end sound card and Vengeance 1300 are a great combination for making that happen.
The results of obsessive audio engineering
The massive 50mm drivers greatly reduce the overloading and distortion that can occur with gaming headsets that use 40mm drivers. You get more accurate sound reproduction (particularly for the all-important low-frequency effects). You hear more audio, more cleanly, and you get a competitive advantage.
The extra-wide, extra deep earcups don’t just help things sound great — they feel better, too. Customize your comfort with your choice of the included microfiber or synthetic leather covers. Both use memory foam earpads for a comfortable, reliable fit that conforms to the shape of your head without binding or pinching.=
The circumaural, closed-back design blocks distracting sounds and keeps your head in the game, and the extra-large inline volume and microphone control is easy to grab and use when the action heats up you don't need to take your eyes off the screen.
Whether you’re barking instructions to your teammates or chatting with old friends, you deserve to be heard. The unidirectional, noise-cancelling microphone is tuned to capture your voice loudly and clearly, while screening out distracting background noises. And, it flips out of sight when you’re not using it.
You need more than just dramatic audio. You need the comfort that allows you to play or talk for hours without thinking about what’s on your head. You need fidelity that gives you a listening experience that’s not just immersive — it must also be true to the source material. And, of course, you need the detailed positioning and situational awareness that lets you play your best.
- Vengeance 1300: Your sound card meets its match
- Intense, Immersive Gaming
- Superior Comfort
- Large 50mm Audio drivers
- In Line volume control
- High-sensitivity noise-cancelling microphone with flexible boom
- USB and analog connections for universal compatibility
- Two Year Warranty
Was [£69.98 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Roccat Kave 5.1 Surround Sound Headset @ £59.99 inc VAT
nonl2br
<br>
A Desert Eagle isn't worth its fancy name, if you don't know where to aim. Imagine your advantage within the heat of the battle when you exactly hear where your opponents are before you can actually see them. Knowing the position of your enemy is half the frag. Realistic 3D surround sound makes you locate your opponents easily by the noise they generate. The desktop control enables you to adjust to situations quickly with sound and microphone mute buttons and volume control for different channels. <br>
<br>
- Real 5.1 Surround sound with speakers aligned at a 12° angle<br>
- Microphone with mute LED fully rotatable and completely removable<br>
- Tip’N’Control desktop remote for central management of all volume functions<br>
- Dual sound-profile with movie and game settings<br>
- Solid aluminium hinges enabling heavy duty use<br>
- Hand-sewn comfortable earcups featuring external noise cancelling<br>
- Adjustable vibration unit for a realistic gaming experience <br>
- Headband with three pads for equal weight distribution<br>
- Easy to carry folding and compact design <br>
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/125bfd1f2f2cc9251cc512dfde5e4fb1.jpg">
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/f620e869ce025933aeef18e4d0fd3894.jpg">
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/798d360d6701787365c7266f8cf96fbe.jpg">
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/48545abd6c12c63d38c082c343da0099.jpg">
<br>
<script type="text/css">
#youtube {
float:right;
margin-left: 50px;
</script>
<div id="youtube">
<iframe width="640" height="390" src="http://www.youtube.com/embed/yEyXafzsrB0" frameborder="0" allowfullscreen></iframe>
</div>
Was £65.99 Inc. VAT
ORDER NOW
Logitech G35 Gaming USB Headset PC 7.1Ch Surround @ £109.99 inc VAT
The Logitech G35 headset. Game-changing immersion with 7.1 surround sound powered by Dolby technology for a detailed soundfield - hear your enemies before they see you. Featuring three swappable headband pads so you can choose the best fit, for long-lasting comfort; three customizable G keys for one-touch command over music, voice morphing, and more; on-ear audio controls for quick access to volume, microphone mute, and surround sound adjustments; and an adjustable, noise-canceling microphone that focuses on your voice and reduces background noise.
- 7.1 surround sound powered by Dolby technology delivers a detailed soundfield - hear your enemies before they see you.
- Three swappable headband pads let you choose the best fit, for long-lasting comfort.
- Three customizable G keys give you one-touch command over music, voice morphing, and more.
- On-ear audio controls provide quick access to volume, microphone mute, and surround sound adjustments.
- Adjustable, noise-canceling microphone focuses on your voice and reduces background noise.
- 2-years limited warranty
Was £119.99 Inc. VAT
Only £109.99 inc VAT.
ORDER NOW
- Distortion: 0.1%
- User manual
Was £69.99 Inc. VAT
ORDER NOW
Was £98.99 Inc. VAT
ORDER NOW
Features
Specifications
ORDER NOW
Specifications:
Was £49.99 Inc. VAT
ORDER NOW
- Weight: 9 Kg
ORDER NOW
- Weight: 9 Kg
ORDER NOW
Was £24.99 Inc. VAT
ORDER NOW
- 2 Years Warranty
Was £29.99 Inc. VAT
ORDER NOW
- Superior Comfort
- Two Year Warranty
ORDER NOW
nonl2br
<br>
<br>
<br><br>
<br><br>
<br><br>
<br><br>
<br>
#youtube {
float:right;
margin-left: 50px;
</script>
<div id="youtube">
</div>
Was £65.99 Inc. VAT
ORDER NOW
ORDER NOW
