I recently bought a samsung LED TV and it only has optical out, no 3.5mm jack or any other sound output that i can find (tell me if im missing something).
As such my current speakers dont work with it since they are analogue.
I dont want particularly good ones or anything as i dont use it as often as my pc etc.
Previoulsy i just had the cheapest 2.1 system from logitech i could find as all i wanted was a subwoofer so i could have some bass in games/music, hence the not wanting to spend much.
It only needs one optical input as then i can run it through the tv, otherwise itd need enough inputs for my xbox 360, wii, HTPC and tv.
So, cheap and cheerful 2.1 optical speaker system for a tv plx.
if no such thing exists then....adaptors?
