- 24 Jun 2003
Thought i would reinstall an old favorite back onto my pc again , the game is Question is MOH:Spearhead ( same error appears with MOHAA as well )
Since i last had this game installed i have obviously changed my graphics card , and now i am using an x1950xt
the when i select a screen resoluition greater than 1024 x 768 i get the folowing error
I have uninstalled both the game and the drivers and yet the problem persists .ideally i want to be able to run the game in 1440 x 900
I have the game installed on another pc with a 7800gt and the game runs the higher screen resolutions fine on that pc.
Also atm even though i can run it at 1024 x 768 the game seems laggy at times ( graphical lag ) and also a bit blurry
Code:
------- Sound Initialization Complete ------- 82 ms
Setting up Shaders
Loading inventory...
----- Client Initialization Complete ----- 1187 ms
--- Common Initialization Complete --- 1983 ms
Working directory: C:\PROGRA~1\EAGAME~1\MOHAA
Loading Localization File global/localization.txt
------- S_StopAllSounds (stop music) -------
------- S_StopAllSounds Complete-------
trFMV::play(), playing EAlogo.RoQ
r_mode will be changed upon restarting.
-------- CL_Vid_Restart_f --------
------- Sound Begin Registration -------
------- Sound Begin Registration Complete -------
RE_Shutdown( 1 )
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...hiding window
...destroying window
...window successfully destroyed
...resetting display
...shutting down QGL
...unloading OpenGL DLL
----- Initializing Renderer ----
----- R_Init -----
Cmd_AddCommand: r_infostaticmodels already defined
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded
...setting mode 8: 1280 1024 FS
...using colorsbits of 32
...calling CDS: failed, bad mode
...trying next higher resolution: failed, bad mode
...restoring display settings
...created window@3,22 (1286x1056)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 32, 0 )
...53 PFDs found
...hardware acceleration found
...PIXELFORMAT 5 selected
...creating GL context: succeeded
...making context current: succeeded
...WARNING: fullscreen unavailable in this mode
...using colorsbits of 16
...window already present, CreateWindowEx skipped
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
Called FadeSound with: 0.000000
------- Sound Shutdown (full) -------
------- S_MILES_StopAllSounds -------
------- S_MILES_StopMP3 -------
------- Q_AIL_shutdown -------
------- S_MILES_FreeDLL -------
------- S_MILES_FreeDLL Finished! -------
------- Miles DLL Removed -------
------- Sound Deallocation (4) -------
Deallocating 0x 4 (Done)
------- Sound Shutdown Complete -------
GLW_StartOpenGL() - could not load OpenGL subsystem
