Spec a Build...Another one!
15 Dec 2008
Cheshire
Hi all,
I'm after the following components and wanted some advice on which way to go in terms of AMD vs Intel and maximum speed.
I don't tend to overclock, but if a CPU is proven to OC without any potential issues then I'd consider it.
  • Motherboard
  • CPU
  • PSU
  • RAM
Mainly do gaming, word processing and occasional CAD/design work.
I want the best possible system within a budget of £200. I have everything else needed for the build, just these components needed.
AMD X2 or Intel Dual!?
Thanks in advance,
Andy
Akasa Ultra Quiet 400W Paxpower PSU
Intel E2200 CPU
Corsair 4gb 6400 800Mhz DDR2
Gigabyte GA-EP43-DS3L Intel P43
Total Price: £215.00
Edit: Thats the cheapest I can make it on here. Unless you wanna go really budget? (ASRock motherboard, OcUK Value RAM etc.)
What GPU do you have?
Abit IP43 Intel P43 (Socket 775) PCI-Express DDR2 Motherboard Abit IP43 Intel P43 (Socket 775) PCI-Express DDR2 Motherboard £59.99
(£68.99)
Intel Pentium Dual-Core E2200 "LGA775 Core 2" 2.20GHz (800FSB) - Retail Intel Pentium Dual-Core E2200 "LGA775 Core 2" 2.20GHz (800FSB) - Retail £49.99
(£57.49)
Akasa Ultra Quiet 400W Paxpower Active PFC ATX2.2 PSU - Black Nickel Akasa Ultra Quiet 400W Paxpower Active PFC ATX2.2 PSU - Black Nickel £34.99
(£40.24)
Corsair 4GB DDR2 XMS2 PC2-6400C5 TwinX (2x2GB) Corsair 4GB DDR2 XMS2 PC2-6400C5 TwinX (2x2GB) £31.99
(£36.79)
Sub Total : £176.96
Shipping cost based on delivery to Credit/debit card billing address, G69 6AP with:
Shipping : £8.99
VAT : £26.54
Total : £203.50
