Hi all,
Looking to put together a cheap as possible build. It'll mainly only be used to play Quakelive/Quake 4 on a iiyama VM PRO CRT, so it's not going to need much grunt! My budget is as close to £150. I'm open to both AMD and Intel. My case is a Corsair 600T, so the motherboard has to be able to power the case fans.
Will need:
Motherboard, CPU, RAM, PSU
Don't need:
Case, OS, monitor, GPU, HDD, DVD drive, Mouse/Keyboard
Will also check the MM out
Much appreciated
Will need:
Don't need:
Much appreciated
