Spec advice please
6 Oct 2008
Hi,
I'm looking at building a Vista PC (possibly 64-bit version of the OS). The main use of this system will be photoshop/lightroom/dreamweaver and some software development using the MS dev tooling. Gaming may be something that I do in the form of games such as WAR and Company of Heroes.
Would the following spec work well and would I be able to overclock the processor safely
I'd agree. That spec is decent all the way through then the HDD is a league below certainly not worth skimping on as Storage is very cheap right now.
The Case+PSU combo looks a little budget to me, perhaps one of the Antec gaming cases might be more appropriate and a good brand PSU.
One problem, you've picked a micro-atx case and picked a full size atx board. If you want a matx board, I can recommend the Asus P5E-VM HDMI mATX mobo. Will let you overclock that cpu easily.
http://www.overclockers.co.uk/showp...ATX (Socket 775) PCI-Express DDR2 Motherboard
Also I'd change that harddrive to the Samsung Spinpoint f1 320gb, I've got one myself and there fast enough for everything. http://www.overclockers.co.uk/showp...nt F1 320GB SATA-II 16MB Cache - OEM (HD322HJ)
Rest looks fine :)
