My current PC, as per sig, was my first self build around 3 years ago.
I normally tend to start thinking of a replacement every 3 years or so and would appreciate advice on a new build.
Once the new build is up and running the current PC will be my spare so I won't be gutting it completely although I will take the 2 x Samsung F3 1 Tb HDD's out for the new build for general storage and back-up.
I'm looking at a decent spec which hopefully will still be reasonable in 2 or 3 years time when no doubt I'll start again.
No specific budget but I don't want to waste money either.
I want a QUIET PC. If need be I'll swap some fans out of the current PC which are very quiet.
Main uses are pretty standard, plus some CAD work, occasional Photoshop, TV via Freeview Card and HD TV via Satellite card, some Video editing etc.
It won't be primarily a gaming rig by any means but I have dabbled in that direction occasionally.
It'll probably be a few weeks before I order but unless there is something very startling coming in the next month or so at most, I'm not inclined to delay because you are likely to find there is then something else just round the corner and you just keep delaying it.
I'll be using an Intel CPU and since I found overclocking my Q6600 incredibly easy anticipate overclocking the CPU but nothing else.
I have the Monitor, keyboard etc.
Provisional Spec:
CPU: Intel Core i7 950 3.06GHz (Bloomfield) (Socket LGA1366)
£240
GPU: Sapphire ATI Radeon HD 5850 Toxic 1024MB GDDR5 PCI-Express Graphics Card [11162-05-40R]
£250
I think this card will fit in the case ?
Motherboard: Asus P6X58D-E Intel X58
£150
Probably more of an enthusiast's choice but seems very good value
I might as well get one capable of supporting USB 3 and SATA 3 ?
Ram: 6 GB - OCZ3G2000LV6GK - on ASUS QVL
£130
Edit: - it would be desirable to use Ram which I could easily add to in the future ie up to say 12 Gb or whatever
SSD: Intel X25-M Mainstream 80GB 2.5" SATA-II Solid State Hard Drive (SSDSA2MH080G2R5)
£160
Not the cheapest but my preferred and simple option - ie supported by Intel's Toolbox
HDD - Storage & Back-up: existing 2 x Samsung F3 1 TB
Case: Lian-Li B25FB
£125
I prefer a good old fashioned looking case and have been very pleased with my existing Lian-Li.
PSU: Corsair HX 750W ATX Modular SLI Compliant
£120
Not sure if I need that much power ?
I have no plans for expansion but it could happen and would prefer some spare.
Current unit is a Corsair and am tempted for another modular unit
CPU Cooling: Corsiar H 50
£63
Hopefully this will be adequate and quiet although it could be a bit, dare I say, 'gimmicky'.
Are pumps inherently less reliable than fans ? - reliability is very important to me.
Total Cost around £1500.
Provisional Spec:
£240
£250
£150
£130
£160
Case: Lian-Li B25FB
£125
£120
£63
