Spec build for a friend...
16 Feb 2014
North West England
Going to be helping a friend build a computer but he wants a spec off you guys first :D
£1300 is the budget just for the tower with the os included.
He wants the corsair 540 case, and hes going for a nvidia gpu
The computer will be used soley for gaming, and he already has a 1tb hd so its just the ssd he needs. :)
He would also like options for watercooling if possible.
Two offerings (with some bling and colour-matching so not best bang for buck) to get things going.
White/black/orange:
YOUR BASKET
1 x Gigabyte Z97X-SOC - Devil's Canyon Intel Core i7 4790K OEM CPU & Motherboard Bundle **£40 OFF** £370.98
1 x KFA2 GeForce GTX 970 OC Silent "Infin8 Black Edition" 4096MB GDDR5 PCI-Express Graphics Card **WorldWide Exclusive** £289.99
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Arctic White (CC-9011048-WW) £126.95
1 x EVGA SuperNova G2 750W '80 Plus Gold' Modular Power Supply £94.99
1 x Corsair Hydro H110 280mm High Performance Liquid CPU Cooler (CW-9060014-WW) £91.99
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £77.99
1 x Crucial BX100 250GB SSD SATA 6Gbps 7mm Solid State Drive (CT250BX100SSD1) £76.99
2 x TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLAED38G2400HC11CDC01) £55.99 (£111.98)
1 x BitFenix Alchemy Cable Bundle - Orange £21.95
1 x NZXT CB-LED20-WT 24x White LED Sleeve - 2m £13.99
1 x LG 24x DVD±RW SATA ReWriter (Black) - OEM GH24NSC0.AUAA10B £13.99
Total : £1,291.80 (includes shipping : ).
Rad fans/rear fan replacement (over budget):
YOUR BASKET
3 x Alpenföhn 140mm Wing Boost 2 Plus PWM Fan - Orange £9.95 (£29.85)
White/black/blue:
YOUR BASKET
1 x MSI Z97S SLI Plus - Devil's Canyon Core i7 4790K OEM CPU & Motherboard Bundle **£35 OFF** £336.97
2 x Avexir Core Blue Series 8GB (2x4GB) DDR3 PC3-17000C11 2133MHz Dual Channel Memory Kit (AVD3U21331104G-2CI) - Blue Light £65.99 (£131.98)
1 x Silverstone Cable Extension Value Bundle - Black & Blue £13.16
1 x Silverstone PCI 8-Pin to 6 +2- pin PCIe Cable 25 cm - Black / Blue £4.24
1 x No Molex to SATA Adapter Required £0
Total : £1,277.47 (includes shipping : ).
YOUR BASKET
3 x Alpenföhn 140mm Wing Boost 2 Plus PWM Fan - Blue £11.99 (£35.97)
Thanks for the reply , he'd like just a 2 colour scheme with the black 540 case and it's just going to be air cooled ! also want the pre braided cable kit if poss :)
YOUR BASKET
1 x Gigabyte Z97X-Gaming 7 - Devils Canyon Core i7 4790K OEM CPU & Motherboard Bundle **£40 OFF** £363.98
1 x MSI GeForce GTX 970 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card £281.99
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Black (CC-9011030-WW) £114.95
1 x Kingston HyperX Savage Red 16GB (2x8GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (HX324C11SRK2/16) £95.99
1 x CableMod E-Series G2 & P2 Cable Kit - Black / Red £69.95
1 x ACX EVGA CPU cooler, Black - 120 mm £35.99
Total : £1,227.82 (includes shipping : £12.50).
YOUR BASKET
1 x Gigabyte Z97X-UD3H-BK - Devil's Canyon Core i7 4790K CPU & Motherboard Bundle **£15 Saving + Gigabyte Free Upgrade ** £397.98
1 x TeamGroup Vulcan GOLD 16GB (2x8GB) DDR3 PC3-17100C11 2133MHz Dual Channel Kit (TLYED316G2133HC11ADC01) £101.99
1 x CableMod E-Series G2 & P2 Cable Kit - Black £69.95
1 x Be Quiet! Dark Rock 3 CPU Cooler £54.95
Total : £1,279.78 (includes shipping : ).
Board has a 5yr warranty and a free exchange to a newer board in 3yrs - http://forums.overclockers.co.uk/showthread.php?t=18631511
That's a beauty of an air-cooled black/red spec from Stu. I'd probably spend the money for the CableMod cables on some nicer fans to match (given the PSU is hidden at the back and you'll only see four cables in the interior which you can get extensions for).
By the way, this filter can be taped to the bottom (fits perfect, just need a bit of sticky tape) and helps prevent dust as well as helps a bit to hide the hot-swap bay holes on the bottom:
YOUR BASKET
1 x Silverstone SST-FF142B Magnetic Fan Filter - 320x155mm £5.99
One for the PSU vents is also handy (anything 140mm-200mm size) for that case.
just any cable set will do one that will look nice :) and stu coucheers for the reply that build looks epic, which all in 1 water cooler for the cpu would be best please ??
Thanks for the replies people :) .. stu he's going to go for that build , his card has played up so he's going to ring and order on Monday will post pictures next weekend :)
