- 9 Jan 2010
- Lancashire
Can people just check this spec please:
Don't need os, optical drive, monitor keyboard, mouse or speakers.
I plan on upgrading it later on and overclocking btw (titan fenrir, more case fans more hdds)
So far the only thing i'm not sure about is the case.
Notes:
GPU: good enough for gaming at 1920x1080
CPU: presume this is the best for this budget
RAM: Can't get the ocz reaper cause of the mobo (low profile ram is required if a big cooler (e.g titan fenrir) is installed.
MOBO: Apparently good at overclocking and quite cheap, don't need sata 6Gb/s or usb 3.0 but they would be nice.
PSU: Cheap should be enough for all the hardware including overclocking the cpu and gpu and about 3 hdds
HDD: Good 500GB hdd
CASE: leaning towards the antec 300 but i want ideally; black interior, cable management holes, good airflow, simple looks, psu intake at the bottom, quite small, good build quality. Any recommendations?
So far i have considered:
Antec 300: no black interior, no cable management, no psu intake at bottom.
NZXT Beta Evo: has pretty much everything i want but cheap build quality and not so nice plasti front.
CM 690 II advanced: a bit big, quite expensive, doesn't look so good with an optical drive in spoiling the looks.
Xigmatek Utgard: The orange looks nice but i'm not sure if i could live with it tbh.
Fractal design r2: is heavy, not too keen on the white but could live with it, reports of it smelling of bitumen(sp?), air cooling not so great.
ATM i'm inbetween the antec 300 and the cm 690, just trying to convince myself its worth it.
So Any help overclockers?, i'm pretty sure my spec is fine just need convincing on a case...
Notes:
HDD: Good 500GB hdd
