Spec check £850-950
18 Feb 2009
I'm thinking of replacing my 5 year old machine (P4 3Ghz, 1GB RAM, GeForce 5900, XP Pro) with a new build. Comments would be appreciated on the below spec if you see anything that might be an issue or I could improve upon. Budget is £850-950 including OS and new monitor.
PC used for gaming, 3d animation, and web development for which I run virtual machines for different servers (XP and Ubuntu).
Intel Core 2 Quad Q9400 LGA775 'Yorkfield' 2.66GHz 6MB-cache (1333FSB) Processor - Retail £190.89
Asus P5Q Pro Intel P45 (Socket 775) PCI-Express DDR2 Motherboard £114.99
OCZ 4GB (2x2GB) DDR2 PC2-8500 Gold Edition 4GB Dual Channel £43.69
XFX Radeon HD 4850 512MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail £114.99
Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache - OEM £51.74
Pioneer DVR-216DBK 20x DVD±RW SATA Dual Layer ReWriter (Black) - OEM £19.54
Sunbeam Core Contact Freezer CPU Cooler (Socket 754/939/940/AM2/LGA775) £28.74
Coolermaster Centurion 590 Case - Black (No PSU) £54.04
Coolermaster Real Power 620w Modular Power Supply £78.19
Microsoft Windows Vista Home Premium SP1 64-Bit - OEM £91.99
Samsung T200 20" Widescreen LCD Monitor £137.99
Total £926.77
Do some research into the barracudas, make sure you haven't got the bad firmware. I'm pretty sure it was the .11's but I haven't read up on it much, as I'm sure you can tell :)
It was the 7200.11's but even so i would be a bit wary of going with them. i would swap to a 640Gb Samsung Spinpoint F1 or Western Digital AAKS drive. I suggested 640Gb as they both have 320Gb platters so should be faster than a 500Gb drive.
seeing as you don't upgrade much, maybe best to spend a little extra for an i7? could do it for just under £1100 with screen and OS
anyway your specs looks fine and it will be night and day with your current
Thanks for the replies, will definitely go with the Samsung 640GB hdd as it's only £3 more. I had thought about the i7/DDR3 but the prices seem to be quite high still and I probably won't leave it another 5 years before upgrading again ;)
XFX cards seem to be the cheapest, what's their reputation like compared to other manufacturers and should I spend £6 more and get the Asus Radeon 4850 which comes with an extra years warranty?
