Would thie be a worthwhile upgrade from my current system (see sig for spec)? The plan is that I can later add a second graphics card and double the memory to 8GB. What do you think?
Also I've tried to shave the price down as much as possible as I've just bought a new car so want to try and spend as little as possible, whilst still keeping a worthwile system. If you can see anything I can change for a cheaper part let me know!
Thanks
