Spec check again please
18 Oct 2002
Earth
looking at the this for my final set up.
I'm still a little torn between the Asus P8P67 Intel P67 or the Sabertooth though i do like the design on the sabertooth.
Always liked the thought of the H50 instead of using a fan as such though is it a good piece of kit?
Input please need to order today .
Thanks.
What are you using it for?
I'd go for the P8P67, but go for the Sabertooth if you want to spend the extra money.
The H50 is reviewed well, although CPU fans present better value for money.
Well ordered the H50 and will debate over the weekend over a mobo.
I always use Geil and never had a issue with them though if there's a good deal over the weekend on ram I will look at that.
It's just the mobo I'm debating on.
