I have compiled this list so far to go in a Corsair 540 Air.
There is a couple of things i am not sure about;
Do i need any angled fittings?
Is a QDC good to use to drain the loop or should i be looking for something else? if it is spec me one and tell me the best place to fit it please.
Which pre-mixed fluid should i use? i want clear but theres 2 options. As i am new to it i want something thats ready to go.
Which bridge should i use to go between the two cards on the following board: http://www.overclockers.co.uk/showproduct.php?prodid=MB-514-AS&groupid=701&catid=5&subcat=2261
If theres something i've overlooked please tell me
Proposed spec:
YOUR BASKET
1 x EK Water Blocks EK-D5 Vario X-RES 140 (incl. pump) £107.99
2 x EK Water Blocks EK-FC7970/R9 280X - Acetal CSQ £75.95 (£151.90)
1 x EK Water Blocks EK-Supremacy - Nickel £52.99
1 x EK CoolStream Radiator XT 360 (120.3) £48.98
1 x EK CoolStream Radiator XT 240 (120.2) £38.99
2 x Monsoon 16/11mm (ID 7/16 OD 5/8) Free Center Compression Fitting Six Pack - Matte Black £27.95 (£55.90)
1 x EK Water Blocks EK-FC7970/R9 280X Backplate, CSQ £20.99
1 x Primochill Primoflex Advanced Tubing 16/11 - UV Blue £5.99
Total : £495.72 (includes shipping : £10.00).
Proposed spec:
YOUR BASKET
