My i5-2500 hardware is beginning to show its age and get a bit flaky and following a graphics card meltdown, which despite the good advice from @Vince and others in the GPU forum only bought me a few more weeks to decide what to aim for and save some pennies I need to upgrade.
So I'm looking for a quick sanity check before ordering. My main uses are Gaming (1440p @ 60 Hz), Photo editing (ACDSee), GIS (QGIS - mainly cartography rather than data processing). I also dabble with graphics and VMs but nothing really serious.
I can reuse my case (Corsair 330R) and drives (250 GB Samsung EVO SSD, 2x WD HDD), my PSU (Corsair TX 750W V2) I'm intending to drop in my bits box and replace.
Budget is fairly flexible, but not wanting to spend more than £1,200 all in, ideally lots less. The case lives under my desk, so I can forgo infesting it with RGB.
My basket at Overclockers UK:
With everything getting much more energy efficient, I'm wondering if the 550W PSU will suffice and which of the following RAM options would be best to go for - I'm not sure if the 3600 kit will ideally need a BIOS update to run at full speed.
Looking to order tomorrow, but probably after the offers change (I can hope there is a deal on GPUs...).
- 1 x AMD Ryzen 7 Eight Core 2700X 4.35GHz (Socket AM4) Processor - Retail= £319.99
- 1 x Gigabyte X470 Aorus Ultra Gaming AMD X470 (Socket AM4) DDR4 ATX Motherboard= £125.99
- 1 x Gigabyte GeForce GTX 1070Ti Gaming 8192MB GDDR5 PCI-Express Graphics Card= £469.99
- 1 x Seasonic Focus Plus 550W 80 Plus Gold Modular Power Supply= £79.99
- 1 x Team Group Xtreem T-Force 16GB (2x8GB) DDR4 PC4-28800C18 3600MHz Dual Channel Kit - Black= £179.99
- 1 x Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Black/Grey (TLGD= £169.99
